TX: Aftermarket & OEM B Series parts, JE, ARP, Moroso
I am selling several parts that have been for sale locally only but decided I will consider shipping some of them.
All are in excellent shape and the internals were only installed and test fired, never ran.
Feel free to ask any questions. Located in DFW area, TX. All prices do not include Paypal fees or shipping.
1. JE 85mm turbo pistons with rings. They are JE part no. 295732 which is for an 85mm bore block. They have a -3.4cc dish which is around 9:1~10:1 compression depending on head used. These pistons are for high hp turbo applications which means a full skirt and the upgraded high strength piston pins.
$300
2. Honda/Acura LS size Bridgeway/BW Crank 4130 Billet Connecting rods. These are a very high quality set of rods that come with the optional ARP 625+ rod bolt upgrade. They are part no. 4-BR-013-01.
Here's a link to their website where you can find the part number:
bwcrank
$375
3. Honda/Acura OEM oil pump modified by KMS. This was going on my engine build and was test fired but never ran, basically brand new. These are modified by KMS for more volume and more flow for high performance Honda engines. Will fit most Honda/Acura B series blocks.
OEM Honda part no. 15100-P72-A01
Sold
4. Fluidampr crankshaft pulley for the Honda/Acura B series engines. It is in good shape, however it does have a slight nick in the A/C pulley which never caused problems for me.
Fluidamper part # 590601
Sold
5. ARP main stud kit for the Honda/Acura non-vtec b series blocks. ARP part# 208-5404.
All studs, washers and nuts are included like a normal kit. Zero damage at all, only installed and test fired.
$50
6. Moroso race oil pan for Honda/Acura B series engines. It is in great shape and this particular model is hard to find as it is no longer made. It is a very thick, welded aluminum pan. They are all thin stamped steel pans now.
This pan includes the pickup needed to work correctly. It has two AN oil drain back plugs for a turbo application or catch can drain back. This is an excellent oil pan for racing with increased capacity and better oil control with trap doors around the pickup.
Will fit any B series block, but wont fit with a Type R transmission brace.
Sold
7. Honda Acura ITR/CTR B series Vtec camshafts. They are in great shape. You can identify these camshafts by the markings on the end in one of my pictures.
Comes with the ITR cam gears pictured.
Sold
8. Full ITR Valvetrain with valves, springs, and retainers
$250
Feel free to call or text, or PM with any questions.
Two 8 One - 732 - Two Six Three Zero
$300
bwcrank
$375
Sold
Sold
$50
Sold
Sold
$250
