Are you serious, you need the bumper/bumper support/rad support/wiring for the headlights/fenders/hood/headlights and the hood release cable. And since you said type r headlights you meant the OEM HID, which will not work with your stock washer fluid bottle so you'll need to remove it or get the jdm itr one. Over here the non-hid conversion is around $6-700 is "ok" shape the OEM HID ones are $1.2K give or take 100$, as for misc items around $60 doing it isn't hard getting it to line up is difficult you will need to weld some parts of it.
it's call the "JDM FRONT" and it's been around as long as the DC body style so there were tons of topics on it, why would you need a wing?.
Cheers , there's a few itr for breaking so I should get them cheap enough , where I live we call fenders wings, and don't jdm integras share the same light wiring as jdm itr ?
I assume there are some good guides on here for this ?
ok fair enough about the "wings", I mean your current headlights are 9005/9006 and have 2 round-ish plugs. The "jdm front" lights use a square brown plug the easiest way is to make sure you have the harness side of that brown plug then wire it directly. I assume password:jdm items are hard for you guys to get, if not there a simple plug and play harness for $35-USD. Yup I have done 2 both in my build threads here the link I used when I first started Phenom3030's DIY JDM Front Install - Team Integra Forums - Team Integra
you can leave the bottom section and just cut the "T-section" but cutting is required get a angle grinder or cut off wheel. they're 40-100 over here.
