B18C Innovative billet hydro mounts and hood wont close properly
Old Mar 25, 2015 | 04:32 AM
hondatuner020's Avatar
Default B18C Innovative billet hydro mounts and hood wont close properly
I have a b18c-r with billet innovative mounts and the hood wont close properly, its sitting tight ontop of the motor, the pass side is flush with the fender, but the drivers side is 4-5mm above the fender. They state no hood cutting, so im unsure of why this is happening. I cut the webbing by the front drivers corner of the valve cover and it didnt help, it almost seems like its hitting in the middle and laying completely on the motor.
Old Mar 25, 2015 | 04:40 AM
acmoc's Avatar
Default Re: B18C Innovative billet hydro mounts and hood wont close properly
innovative is a **** company. there's a reason hasport costs more.
Old Mar 25, 2015 | 08:47 AM
And hasport mounts dont fit the stock hood with a b18c either............
Does anyone have experience shimming the motor mounts down to clear the hood?
Old Mar 25, 2015 | 09:50 AM
mynameis_jeff's Avatar
My friend in his b20v rubs the valve cover on the hood at the top left corner. Just some slight fitment issues
Old Mar 25, 2015 | 11:21 AM
Hasport's Avatar
our mount kit was designed around the b16a which is a tad bit shorter than b18b/c and b20
with that being said every 88-91 is different in terms of fitment. ive seen some that fit b18 and b20 fine and some that dont. some that fit b16 fine and some that dont
you have to remember these cars are 25 years old now. which is older than most people driving them
Old Mar 25, 2015 | 11:35 AM
.Grimace's Avatar
footwork mastery
I have been fighting this too. My b18c won't fit and the part of the hood with zero webbing is hitting too. I just had to raise the rear of the hood looks bad.
Old Mar 25, 2015 | 11:58 AM
My hood is all dented from its years of abuse before me, i have a new one on order. im going to cut the webbing out over top of the valve cover on my old one and see what that does. if that still dosnt work Im going to add some washers under the drivers and passenger mounts to drop the motor 1/8 - 1/4 inch.
Old Mar 25, 2015 | 12:46 PM
See_5's Avatar
I had the same problem w/ Hasport mounts throwing my GSR w/cable trans into my EF. I bought some streetRays spacers and it closes now. There is still some contact on driver side because the hood is up more on that side but the latch works and Im planning on working on it after all the turbo work is done. You can see in the pic that the hood is pinching on the passenger side. Not a fan of the spacers but its functional and i didn't cut any webbing. Its a cheap certifit hood and Im trying to avoid as many outward dents as possible.
Old Mar 25, 2015 | 03:28 PM
Deetz's Avatar
Crazy Honda Guy
Why not just get the slightly raised hood you can find from VIS, or do a 1990+ jdm or edm front end conversion. It will give the extra clearance, plus look really good!!
here is a good example, minus missing the corner len's
Old Mar 26, 2015 | 06:03 AM
Problem solved
Old Mar 26, 2015 | 10:22 PM
whited's Avatar
CRX God
If you are going to paint that, first make sure it is enough clearance. Mine cleared, but when reved you could see it was touching.
Old Mar 27, 2015 | 04:35 AM
That hood actually is pretty beat up, im body working the car and will be cutting and painting a new hood.
94CoupeNY
17
Jan 25, 2013 05:14 PM
Charlie Moua
13
Mar 1, 2011 05:22 PM
Blazin Si
Apr 11, 2005 05:34 AM
CivicB18C1
56
Dec 15, 2004 12:14 PM
TheHatchHog
15
Apr 27, 2003 05:05 AM
