PGM-FI Main Relay
Old Mar 25, 2015 | 04:27 AM
zturek's Avatar
Default PGM-FI Main Relay
Does anyone know how far up the wiring harness does pin 1 of the PGM-FI relay go before it gets routed back to A16 of the PCM?
I seems I have an open connection on this line.
I have a 2000 Honda Coupe
Old Mar 25, 2015 | 06:09 AM
Former User's Avatar
Default Re: PGM-FI Main Relay
HX, EX, Si, DX?
Old Mar 25, 2015 | 06:25 AM
zturek's Avatar
It is an EX
Thanks in advance
Old Mar 25, 2015 | 06:33 AM
Have you tested the wire for an open using a multimeter or are you guessing?
The Grn/Yel wire runs directly from C443 to C452.
Old Mar 25, 2015 | 08:51 AM
zturek's Avatar
Yes tested with an ohm meter open from A16 to pin 1 on the PGM-FI relay.
Should be a straight shot but I do not know how far the Pin 1 side goes
up into the harness before it routes back to A16.
Old Mar 25, 2015 | 08:58 AM
You're overcomplicating a simple problem. Depin the Grn/Yel wire at the main relay connector and at ECU connector A. Cut the connector pins from the broken wire. Resolder a new wire to the removed pins. Plug pins back into the connectors. Enjoy driving your car that now runs. Easy, inexpensive fix.
Old Apr 19, 2015 | 06:02 AM
zturek's Avatar
Sorry for late post. Thanks Ron Definitely Fixed my problem
boarding2008
Jun 2, 2022 01:08 PM
20lb.teg
Oct 17, 2003 07:19 PM
