Semi-urgent: B16 TB gasket - same as B18C5 (ITR) besides diameter?
Old Mar 23, 2015 | 06:35 AM
DSMAddicted's Avatar
Default Semi-urgent: B16 TB gasket - same as B18C5 (ITR) besides diameter?
Gentlemen,
Here's the PN for the TB gasket for a 2000 Civic Si (B16): 16176-P2T-004
I have a B18C Type-R and just got the TB and Intake Manifold back from MaxBore.com.
I need to get a new OEM TB gasket and enlarge the opening so it matches the MaxBore size.
Acura stealership is far from me, but I have a Honda stealer nearby.
Is the gasket the same as mine (16176-P73-004), besides the main opening?
If yes, I could buy the Honda one and save the trek to Acura.
TIA!
Old Mar 23, 2015 | 07:31 AM
Default Re: Semi-urgent: B16 TB gasket - same as B18C5 (ITR) besides diameter?
Ok, I wound up ordering an ITR TB gasket.
Leaving thread open for documentation/informational purposes, it would be cool to know.
Old Mar 23, 2015 | 05:50 PM
Bently_Coop's Avatar
Steve at Heart
b16 has 56mm throttle body. B18's start at 60mm ITR and H22 is 62mm. Not that hard to locate.
Should have taken a picture and measured the new diameter with a caliper/digital caliper.
Old Mar 24, 2015 | 05:38 AM
Thanks for the reply.
I wasn't concerned about the TB inside diameter, but whether or not the other ports and opening matched.
Old Mar 24, 2015 | 05:40 AM
tony_2018's Avatar
Fish Twig
Maxbore doesn't recommend a gasket? Can they cut the gasket to fit your specs?
Old Mar 25, 2015 | 06:40 AM
Yes, they actually offer one. I requested it during my order, but for some reason it was not included (and I was not charged). It happens, nobody is perfect.
But now I am stuck having to modify an OEM gasket, since he makes the custom gasket while boring your TB.
JMelt4
Aug 31, 2007 02:54 PM
Junkyard2000
Nov 11, 2005 02:17 PM
SuperJay
Apr 18, 2005 07:03 PM
dkhuynh
Oct 14, 2004 03:11 AM
granada_sun
Sep 11, 2002 09:11 AM
