1990 Honda Accord only goes in 1st and Reverse
Old Mar 21, 2015 | 03:25 PM
skitt123's Avatar
Default 1990 Honda Accord only goes in 1st and Reverse
However, it will change gears if you manually move the gear shift to 2nd.
I'm pretty sure the transmission is fine. It has been running great. I took it to a friend to change out the fuel pump and then all of the sudden it wouldn't shift gears. I've looked into it and I have seen that it may be a few things:
1. The shift control Solenoid
2. The Transmission Control Unit
3. The transmission itself went out (which I don't think happened)
How do I figure out where to start?
Other issues: the gear shift is locked unless you put the key in to release it. Not sure if this is related. I switched out the brake switch about a month ago when this happened. Now it is happening again.
Thanks for the help!
Old Mar 22, 2015 | 02:50 AM
Lost Again's Avatar
Default Re: 1990 Honda Accord only goes in 1st and Reverse
By chance you did you have the radio on while the fuel pump work was going on? Check the fuses - under hood as well as under dash.
tietie
Apr 18, 2017 03:15 AM
Environs
Apr 19, 2016 07:32 AM
CalamaT
Aug 11, 2007 11:48 PM
theNYguy
Oct 1, 2006 08:14 PM
