Guys help! 2007 Civic!
Hi first time on the forum,, just bought a 07 civic, for pretty cheap. The cars immaculate condition, just doesn't start.
Seller told me story that the car was running perfect, and one day it just didn't start, lol
Anyways its not throwing any codes.
FUEL - OK
AIR - OK
SPARK - OK
COMPRESSION - LOW (Average of 60 - 90 psi between cylinders)
1 out of 6 times when i crank the car will sputter up to 420 rpms and die out.
Should the car still start even with such low compression? I read that is should be above 135 psi to be proper.
What could cause this? Slipped timing chain? Maybe valves went bad but how? Any way to adjust timing?
Checked for headgasket symptoms, but found none, and it would be very rare for the gasket to break between all cylinders anyway.
What should i do next guys? any thoughts?
FUEL - OK
AIR - OK
SPARK - OK
First thing I would do is check timing. If that's all correct, then I would suspect your getting oil on your rings from repetitive attempts, thus increasing compression.
Dlarsson112
Jan 20, 2019 09:07 PM
bingles
20
Nov 11, 2015 11:30 AM
Ross 2.0
12
Aug 30, 2014 06:57 AM
97Preludeguy
Other Make Vehicles
Dec 17, 2009 06:13 PM
erniecombs
Sep 26, 2007 06:21 AM
