Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Crankshaft woodruff key direction on Odyssey
Old Mar 19, 2015 | 06:37 PM
Hondacamaro's Avatar
Default Crankshaft woodruff key direction on Odyssey
Hi could some one please tell me what direction to install woodruff key for crankshaft harmonic balancer on a 2007 odyssey the key is strait with one sovereign angled does angle go towards engine block and down or up or does it go towards crank bolt and washer ange up or down should key stick a little past crankshaft end. Thank you for any help.
Old Mar 19, 2015 | 06:45 PM
Default Re: Crankshaft woodruff key direction
Old Mar 20, 2015 | 05:20 AM
jlk16188's Avatar
Default Re: Crankshaft woodruff key direction on Odyssey
the angle faces towards the engine and touches the crank. It is there to account for the slight angle cut in the crank due to the use of tooling to machine the crank
it is upside down in the picture in respect to the crank
Old Mar 20, 2015 | 10:21 AM
Thank you so much I installed it wrong then I pointed it out thinking the balencer hangs out a little past crank shaft. This key should be able to pull out without timing belt gear moving I hope.
wsudu
Nov 10, 2016 03:00 PM
oranginal
Jul 3, 2009 02:20 PM
212 degrees
Jun 8, 2009 08:09 PM
jackstands
Mar 13, 2005 08:54 AM
egcivic123
Jan 15, 2005 11:46 AM
