94 Accord lx CEL probs
So I just tried pulling the check engine codes off my accord using the paper clip trick and the CEL slowly went on and off constantly. As I seen in other demonstrations the CEL using blinks slowly a few times so you can get the 1st number then the CEL blinks faster and you count those blinks to get the 2nd digit. Anybody know what this means? Im considering just going to autozone to get them to scan it for me
Short blinks are single digit codes 1 through 9. A preceding long blink and then short blink(s) would indicate double digit codes (e.g., 10, 12, 13, 14, 15), followed by a pause for about 1 second.
Your car is OBD-I, autozone's code reader/scanner are generally for OBD-II.
If they are short blinks only, then they are either codes 1 through 9. They will repeat; so, you want to re-check. If you are not sure of the code(s), then try to make a video of the blinking and post it for others to see.
hondacivic97si
Mar 2, 2015 11:20 PM
