auto Transmission install 93 accord help
Old Mar 17, 2015 | 05:24 PM
Honda knowledge's Avatar
Default auto Transmission install 93 accord help
So I am attempting my first transmission install and have a couple questions. first, should the torque converter be installed on the fly wheel with the transmission attached or before? two, is there any real critical procedures that i should know of? Thanks
Old Mar 17, 2015 | 05:47 PM
tim73's Avatar
Default Re: auto Transmission install 93 accord help
Torque converter should be in transmission. Make sure it's fully seated.
Old Mar 18, 2015 | 05:28 PM
MAD_MIKE's Avatar
MM Gruppe B
^ to properly insall it, you will want the TC to be up against the bellhousing to allow clearance of the drive(flex)plate on installation.
This is for a 94-97 but 90-93 should be pretty close.
https://honda-tech.com/honda-accord-.../#post44916843
If you are worried abou the TC slipping off the transmisison use a piece of steel and one of the 10mm headed bolts at the bottom of the bellhousing to prevent it from sliding off.
94-97 PS pump bracket is very useful in this spot.
beany
Jun 1, 2005 08:17 PM
