Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Camshaft Position Sensor location
Old Mar 16, 2015 | 04:34 PM
MacMade's Avatar
Default Camshaft Position Sensor location
I have a 07 Pilot with a 3.5L v6. I recently got an engine code P0344. "Camshaft Position Sensor A - Bank 1 CKT Intermittent". I am trying to find the location of the sensor so I can see if it is damaged and replace it. Please help me find it, Thank you!
Old Mar 17, 2015 | 12:03 PM
belairbrian's Avatar
Default Re: Camshaft Position Sensor location
it is behind the front camshaft pulley. To access it you remove the timing belt cover, timing belt and the camshaft pulley.
It may be just the connector, I can post a pic from the FSM when I get home
Old Mar 17, 2015 | 04:21 PM
Old Mar 18, 2015 | 11:18 AM
MacMade's Avatar
Thank you this is perfect.
Old Sep 11, 2020 | 11:23 AM
Joshua Curtis's Avatar
Originally Posted by belairbrian
can someone help me find the location crankshaft position sensor on a 2006 honda pilot
Old Sep 14, 2020 | 12:09 PM
The crankshaft position sensor is located under the lower timing belt cover. You need to remove the serpentine belt and harmonic balancer/crankshaft pulley, then the lower timing belt cover, which may require removing the upper cover. The good news is you don't have to remove the timing belt to change it.
guildmaster
Jun 2, 2019 04:52 PM
Scotty_06
Jul 3, 2011 09:01 PM
BigGreenAuto
Jan 5, 2007 06:58 AM
sailor
Apr 13, 2003 04:19 PM
