1999 Honda Prelude Massive Oil Leak
Old Mar 16, 2015 | 04:19 PM
kthomas101184's Avatar
Default 1999 Honda Prelude Massive Oil Leak
Take a look at the 41 second video below and tell me if you guys think it is the balance shaft seal.
Old Mar 16, 2015 | 10:26 PM
JDMH22HATCH's Avatar
Default Re: 1999 Honda Prelude Massive Oil Leak
Definitely looks like the front balance shaft seal
Old Mar 17, 2015 | 06:38 AM
snobordboy's Avatar
Moderator
If you are going that far in there, I would replace all of the seals on that side of the engine. Might as well do water pump and timing belt job as well, just so you can button it back up and know that everything is good to go.
Old Mar 18, 2015 | 04:37 PM
Northernlightz's Avatar
x2 ^^^
Old Apr 25, 2016 | 08:41 AM
taruin's Avatar
I had a similar problem in that area, if your prelude has vtec try this. Ive got a 99 honda accord ex coupe 3.0l v6 vtec, I suggest you check the vtec solenoid gasket + oring. Its in that area
Old Apr 27, 2016 | 06:55 PM
thirsk66's Avatar
Wrong the vtec solenoid is not on this side of the engine that is on the other side by the distributor.
ChrisF23
Jan 8, 2018 11:30 PM
carracr625
Jun 16, 2017 06:34 PM
keiths04
Jul 3, 2007 06:25 AM
h22a1lude
Jun 17, 2007 05:47 PM
nholmes
Feb 3, 2005 08:39 AM
