Really odd problem, Temp guage reads half way when I turn on car even when it's cold.
Old Mar 16, 2015 | 10:07 AM
95accordlx's Avatar
Icon2 Really odd problem, Temp guage reads half way when I turn on car even when it's cold.
1995 Civic 4 door 5speed (USA)
Really interesting problem.
Car is cold
Put key in 2nd position gauge goes from resting on the bottom to half way.
As car warms up gauge then goes up to the top and stays
Almost as if the gauge if offset 50 % from normal
Unplug temp sensor under distributer
Reset ignition back to 2nd position
Gauge goes from rest to half way
Thoughts?
Last edited by 95accordlx; Mar 16, 2015 at 10:29 AM. Reason: Forgot to post make and model
Old Mar 16, 2015 | 10:15 AM
Former User's Avatar
Default Re: Really odd problem, Temp guage reads half way when I turn on car even when it's c
Unplug temp sending unit. Post gauge behavior.
Old Mar 16, 2015 | 10:19 AM
95accordlx's Avatar
Pardon my ignorance, is the temp sending unit the one wire under the distributer connected to a unit screwed into the block?
If it is I unplugged it
The gauge goes from rest to half way when turning on the car with this connector unplugged. ( check engine light as well but that is expected since it was unplugged.)
I appreciate your fast reply earlier
Old Mar 16, 2015 | 10:24 AM
It differs depending whether you drive a VW, Ford, Chevy.
Old Mar 16, 2015 | 10:29 AM
95accordlx's Avatar
oops, it's a 1995 Civic LX 4 door manual transmission.
Old Mar 16, 2015 | 10:32 AM
Assuming a stock engine, it's the 1-wire sensor under the distributor.
Old Mar 16, 2015 | 10:34 AM
95accordlx's Avatar
That's what I unplugged and the gauge still goes from rest to about half way when turning on the car.
Thoughts?
Old Mar 16, 2015 | 10:41 AM
Ej8 d16's Avatar
Maybe a connecting screw behind the cluster might be loose.
Old Mar 16, 2015 | 10:42 AM
The problem could be a bad temp gauge or a short in the wire running between the gauge and sending unit.
Old Mar 16, 2015 | 12:24 PM
95accordlx's Avatar
Pulled the cluster out and loosened and tightened the screws for the temp gauge. Still not working right.
Appreciate the suggestion.
Old Mar 16, 2015 | 12:25 PM
95accordlx's Avatar
Was thinking the same thing too.
Old Mar 17, 2015 | 06:06 PM
95accordlx's Avatar
Icon6 Re: Really odd problem, Temp guage reads half way when I turn on car even when it's c
I made a mistake. I thought I was unplugging the sending unit but I was unplugging the other sensor next to it. I went ahead and unplugged the actual sending unit and the gauge went back to rest. I'm assuming the unit is bad. I went ahead and ordered a new one Part# 37750-PH2-014.
Quick questions:
When I install the new sending unit do I need to put anything on the threads (Teflon tape or high temp gasket)?
Will coolant spill out from the hole, I assume it will but just curious if it's not the case.
Again thank you to everyone for their help and a Big thank you to RonJ for your quick replies!
Old Mar 18, 2015 | 05:26 AM
antrmo's Avatar
yes coolant will spill out, and yes I believe you should put the teflon tape onto the new coolant sensor. Have a good look at the wire aswell while its out if it is shorting out somewhere it could be the reason you are getting the false reading
elguy
Feb 21, 2019 03:05 PM
Arthas
Engine Management and Tuning
Feb 8, 2010 09:52 AM
eth0r
Nov 10, 2005 03:31 AM
pburke23
Jul 2, 2004 09:55 AM
h46it
Mar 24, 2002 05:16 PM
