1997 Accord LX, Where is the sunroof switch located?
Alright, so my girl just got her first car a '97 Accord LX 4dr. Its pretty clean. However it does have a hole behind the dome lights with a plug for some sort of switch or something that is MIA. I was wondering if that is where the sunroof switch is supposed to be? If that's not the case then where is it located and what goes in that hole? Any advice or pics would be greatly appreciated. Also, her car is missing the manual which makes it a bit harder to locate some things.
I saw some pictures online. It should be on the same little panel as the cruise control switch by the dash lights dimmer right? Kind of a similar location to where my Integra has it. I went to the junkyard and found a switch. I'll head home after work to see if I can just replace it and be good. Thanks.
