y7 tranny prolly not too healthy
Old Mar 14, 2015 | 02:41 PM
dodt's Avatar
Default y7 tranny prolly not too healthy
i think i should expedite my savings for purchasing & rebuilding a y8 tranny
i always knew i wanted a y8 tranny but after this i think i need to get it done already
just replaced the clutch, flywheel, pressure plate, pilot and throw-out bearing. currently in the breaking-in process. anyways, i knew i should have replaced the axle seals but didn't. was worried theyd leak. constantly been looking under car to see it leaking but it appears to be holding
i drained the less-than-week-old tranny fluid today to see how much was left (to see if it was leaking) and to my surprise it's not clear anymore. it's looking black already, and it was looking extra metallically. so i'm guessing the debris magnet is at it's capacity. but i don't think it's leaking because there was about 1900 ml of fluid in my drain pan. (i emptied 2 bran-new quarts of honda mtf in it the other day)
should there be any gap inbetween the axle head and transmission?
check this tranny fluid:
i think i'm hearing my isb again but it's not nearly as bad as it was a year ago. today on my drive home from work it wasn't really making any noise. but yesterday it was. but tbh it shifts into all gears fine and it doesn't seem like the tranny is in bad shape. but i guess i'll never know til i split er apart
other than a local self serve junk yard, where's a good place to get a used y8 tranny? craigslist? i plan on rebuilding it in my basement while i use the y7 tranny. all bearings and syncros, maybe some forks if need-be... any suggestions?
feed me some juciy information, h-t.
Old Mar 14, 2015 | 06:07 PM
redm3turbo's Avatar
Default Re: y7 tranny prolly not too healthy
pick and pull would be top choice
craiglist 2nd/ marketplace here
ebay 3rd.
where you located? I see them daily on clist in ny
Old Mar 15, 2015 | 07:33 AM
dodt's Avatar
se mich. but what do u think about that tranny fluid color? makes me upset..
Old Mar 15, 2015 | 07:38 AM
tony_2018's Avatar
Fish Twig
So let me ask you, when you first dropped the tranny to replace the clutch did the oil look the same as you are seeiing it now?
Old Mar 15, 2015 | 07:43 AM
dodt's Avatar
it looked worse. but i didn't think anything of it because it had been over a year since the last time i changed it. without splitting the tranny and cleaning it what's the best way to 'flush' a tranny
Old Mar 15, 2015 | 08:26 AM
Jason B.'s Avatar
I'm SE Mich myself, parts galore is the place. You will want to visit the two detroit locations.
Old Mar 15, 2015 | 08:33 AM
dodt's Avatar
hell yea been there lots. the flat rock one is closer. only been to the 2 detroit ones once each. but they do usually have more hondas it seemed
Old Mar 15, 2015 | 08:35 AM
Former User's Avatar
Crack open the transmission and clean the magnet.
With the transmission out and open, replace the axle seals and the input shaft bearing, if suspect.
Yes, about 1/8" or so.
Old Mar 15, 2015 | 12:22 PM
dodt's Avatar
Originally Posted by d15Vteckilla
If you come and mow my lawn and do some dirty work ill give ya the y8 tranny
where u live
jdmstyleEJ6
12
Apr 2, 2010 08:07 PM
fukaintmuven
Nov 19, 2002 08:05 PM
Lei Siew Long
Sep 17, 2001 01:50 PM
