D16y8 block with d16z6 crank. Possible issues???
Old Mar 14, 2015 | 09:15 AM
Blackcougar141's Avatar
Default D16y8 block with d16z6 crank. Possible issues???
I'm purchasing a d16z6 crank for my y8 block. This will be put back into my 97 ex that was D16y8 obd2. Now, I know my y8 has a knock sensor for the crank but using g the z6 crank, doesn't it use a different crank sensor? Also, should I use the y8 crank pulley for the y8 on the z6 crank?
Lastly, since I'll be installing a turbo in the next 3-4 months, and running the obd2 to obd1 rywire harness with ecu, it shouldn't make a difference should it? I've bookmarked dozens of pages and found out what to modify on the block to suit the turbo install. I don't want to blindly throw this engine together, so all help is definitely appreciated! Thank you everyone....
coltron420
May 3, 2019 01:54 PM
LoneAutosport
Sep 10, 2005 08:59 AM
alexsracing
Aug 29, 2005 09:10 PM
Neutex22
Mar 22, 2005 12:42 PM
