92 h22a prelude misfire plz help...
Old Mar 13, 2015 | 05:48 PM
92 h22a prelude's Avatar
Default 92 h22a prelude misfire plz help...
Hi guys I have a big problem plz help...
I have a 92 h22a prelude and it's running rich and tends to misfire .. I checked the compression it's fine I change the TPS sensor with the map sensor and also the TB still misfiring. I have a hard time starting it in the morning. It idles hard before it warms up. The spark plugs are pitch black. My car is running on the stock h23 harness and I'm running p28 ecu I hit vtec that works the harness is a OBD0 and the engine is OBD1 maybe that may be the problem but not sure the check engine light is in its give off code 41 O2 sensor if someone can plz help me thanks!
Old Mar 14, 2015 | 05:34 PM
JDMH22HATCH's Avatar
Default Re: 92 h22a prelude misfire plz help...
Try doing a valve adjustment. Change spark plugs. Clear codes, drive 30 miles and see if 02 comes back on.
Old Mar 15, 2015 | 01:50 PM
Old Mar 15, 2015 | 01:51 PM
iv came to a conclusion I've been using NGK Iridium sparks and they don't burn the gas as fast as the NGK R spark plugs I have my car in the shop right now working on clutch, header new NGK O2 sensor and I'm trying the new plugs. I'll see how it will run I'll let you know thanks!!
Old Mar 15, 2015 | 02:55 PM
holmesnmanny's Avatar
Cant even tell what harness you're running, if your ecu is chipped, base map.
1994lude
Nov 23, 2010 01:04 AM
EJ6SON
Engine Management and Tuning
Dec 10, 2008 01:53 PM
93preludes
12
May 10, 2008 04:24 PM
ilandhopr
Sep 21, 2007 05:35 AM
flaxcon
May 7, 2006 05:21 PM
