Oil leak with pics
Old Mar 13, 2015 | 02:48 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Oil leak with pics
95 d15b7 stock engine CDM CX hatch.
As far as I can tell it looks wet on the full outside rim of the crank seal.
Being oil pump o-ring is internal... How do you know when the oil pump o-ring is starting or has failed?
Old Mar 13, 2015 | 03:01 PM
Former User's Avatar
Default Re: Oil leak with pics
Oil may be leaking from both the oil pump and oil pan.
For the oil pump, a leak from the HondaBond gasket is more likely than the O-ring. Regardless, the pump must be removed either way.
Old Mar 13, 2015 | 03:07 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Sorry Ron, I don't quite understand what your referencing. Are you talking about my pics or talking about my question?
BTW I have the crank seal, both o-rings (two size options for my motor don't know which mine is) and the pickup tube gasket on order, should have tomorrow.
Not sure if I need to do the full meal deal or if I can wait and just do the crank seal for now, clean the area up and inspect in a week or two....
Oh and thank you greatly for providing feedback. I seriously appreciate it.
Old Mar 13, 2015 | 03:12 PM
The O-ring is internal to the HondaBond gasket and would not cause a leak from the oil pump crank seal.
If you replace the oil pump O-ring, then you need to replace the HondaBond gasket.
I also recommend that, in addition to the crank seal, you also replace the oil pan gasket.
Doing all of the above will almost surely eliminate all oil leaks on that side of the block.
Old Mar 13, 2015 | 04:58 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Okay thanks. This is one time having a two piece exhaust header will come in handy.
I'm hoping all the seals come in tomorrow and then I can get everything done on Sunday as Saturday it's supposed to rain, might go out there and work in the rain anyway.
Cheers Name:  beer2.gif
Oh... On the pan gasket, it's only 1.5 years old, so I'm hoping with a real good clean up of all surfaces with brake clean, it will get by. Money is an issue so I'm stretching it for now. If it does leak, I can always drop just the pan and do that gasket later when I have a little cash to spare.
Old Mar 13, 2015 | 05:03 PM
Good luck with the fix.
Enjoy your weekend.
Old Mar 14, 2015 | 05:56 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Thanks Ron, I get one day of the weekend that I don't need to work on the car.
That oil leak was over a year old and when I went to remove the crank seal it spun in location. It was pretty loose. I suspect that was the real culprit and the oil was given lots of time to spread all over the area.
Anyways, everything is back together, cleaned up and the car is running like a top.
Hope everyone enjoys the rest of the weekend as I know I will be.
Cheers Name:  alkashi.gif
Old Mar 14, 2015 | 05:58 PM
Cheers Attachment 391143
somick
Aug 15, 2017 08:14 AM
leighton1245
Apr 10, 2008 10:47 AM
JokerTypeR
10
Jul 21, 2006 12:56 PM
teler86
May 31, 2006 08:54 AM
GruvyTune
Jul 5, 2002 08:57 AM
