2011 Honda accord sunroof not working!!
Opened my sunroof earlier today and went to close it and it's not budging! I hear a clicking noise when I mess with the switch but the sunroof doesn't even attempt to move or close! HELP!!
If you don't hear the motor or it is very weak, the moonroof control unit may be faulty.
The moonroof control unit has the following components inside:
• moonroof open relay
• moonroof close relay
• motor
• CPU
• Hall sensor
Driver's under-dash Fuse No. 20 (20A) supplies always Hot power (+) to the control unit. The CPU uses input from the moonroof switch to provide ground for the relays.
There is a separate open relay and close relay. They work together to operate the motor. When you press open, the open relay coil is energized to provides power (+) to the motor and the close relay resting contacts provides ground (-) to the motor. When you press close, the close relay coil is energized and provides power to the motor while the open relay resting contacts provides ground to the motor, and the motor goes in the opposite direction.
• motor
• CPU
• Hall sensor
If you hear clicking from the relay, it means power (+) and ground (-) are energizing one of the relays; so, it probably would not be due to a fuse.
There is suppose to be a way to try to move the glass with a 4mm hex wrench (after the headliner is removed); but, that may or may not also require removing the moonroof control unit to do that, as it is not shown how that is done.
Try playing around with the moonroof switch (e.g., open, close, tilt. etc.) to see if it changes anything.
Dev1996
Aug 11, 2016 02:38 PM
voodooutt
Dec 24, 2007 09:08 PM
