F23 running on H22 Base map?
Hey what would happen if i run my f23 on an h22 base map? Im asking this because i have access to a full turbo kit from his car. He has a P28 running an h22 base map. Can the f23 atleast run on it until i can get it to a tune shop?
Is it a boosted base map or just a plain H22 base map. Your question is kind of all over the place when you throw in the turbo part. Is the turbo relevant to the question or are you running N/A?
I would not run boost on an unknown basemap. An N/A H22 basemap will not run a boosted F23. An N/A H22 map will run an N/A F23 like complete garbage, VTEC engagement, fuel and timing maps will all be off. Unless you plan on limping your car to the tuner, keeping it out of VTEC and under 4k rpm. I would advise a different basemap or tow your car to the tuner.
What hardware do you have to monitor the engine and how this map will run your engine? Wideband O2, Dataloggiong or monitoring computer software of any kind?
Have you talked to your tuner yet? They would be able to answer all of your questions more specifically.
swrdply400mrelay
Jul 2, 2003 09:15 PM
