How do you know if the balance belt is timed properly?
Old Mar 11, 2015 | 04:17 PM
kenzo42's Avatar
Default How do you know if the balance belt is timed properly?
This is for a 95 Accord EX.
Is it as obvious as a timing belt?
Thanks.
Old Mar 11, 2015 | 05:13 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: How do you know if the balance belt is timed properly?
Lower timing belt cover will have to come off, rotate the crank to the notch verify the other alignment marks are lined up.
Old Mar 11, 2015 | 06:59 PM
holmesnmanny's Avatar
If its not timed correctly you will have bad vibrations reverberating in the cabin.
Alan Roberts
Dec 10, 2018 08:05 PM
curvenut
Jul 24, 2013 06:12 PM
integra3586
Sep 25, 2006 03:57 PM
jamin
Nov 26, 2005 11:19 AM
