08 civic si k20z3 short block 50k *pics* kseries
I have a complete 06-11 civic si k20z3 short block from an 08 civic si sedan. 50k miles on the long block verifiable through carfax (Vin is pictured).
I HAD the complete long block for a couple years. I bought it locally for my swap but I opted to go k24a2. I sold my friend the head for his set up and have this left.*
Since my ownership I've put less than 20 miles on it tops. Not 20k..less than 20 miles! All the components are stock from pistons to the oil pan. I painted the engine because it is a car I show and I'm very meticulous with my engine and bay.*
contents:
-08 civic si block*
-Stock pistons/rods/oil pump/crankshaft/crank pulley etc. (has not been taken apart internally).
-k24a2 water pump components (took the k20z3 parts for the oil cooler parts for mine)
-No timing components (I may have some laying around..I'll give you them if I have them)
-Will include a new k20z3 head gasket from honda less then a couple miles tops if that since install.
**This is perfect for the person that blew their stock block on their civic si and have the head to install or just want to build a k20 block for some more power.
*i keep the engine covered in my garage and still has fluids I will keep in there until the day I have a buyer.
I would recommend milling the deck before installation since there is residue collected. I used a shop in Conroe to do my head for cheap and it is working flawlessly on my friends k20/24 swap.*
NO TRADES..CASH ONLY..NO CASHIERS CHECKS OR PAYPAL..DON'T ASK! PICK UP ONLY! Located in houston, tx!
contents:
-08 civic si block*
JapJunkie
Mar 16, 2004 09:58 PM
