Where is the ecu located/How do u reset??
Old Nov 3, 2002 | 05:27 PM
SoNNyBoY9o9's Avatar
Default Where is the ecu located/How do u reset??
1997 Prelude
Where is the ECU located?
How do i reset it?
Thx
Old Nov 3, 2002 | 05:49 PM
RAB's Avatar
RAB
Default Re: Where is the ecu located/How do u reset?? (SoNNyBoY9o9)
The ECU amoung other computer controls are located under the glove box (more specifically directly under wear a passanger would put his feet.), just pull back the carpet and you also need to remove some panels. To reset the ECU just unplug the negative cable from the battery.
Old Nov 3, 2002 | 06:02 PM
Firedrake's Avatar
Default Re: Where is the ecu located/How do u reset?? (RY8127)
Disconnecting the battery is a lot of work, just pull the clock fuse under the hood for a little while and put it back in....the ECU power comes off that fuse.....along with the clock and radio...
Brian
Old Nov 3, 2002 | 06:11 PM
RAB's Avatar
RAB
Default Re: Where is the ecu located/How do u reset?? (Firedrake)
I was gonna mention the fuse trick but didn't know which fuse it was.
Old Nov 3, 2002 | 06:20 PM
prelude1897's Avatar
go to http://www.ntpog.org for the OBDII workaround
Old Nov 4, 2002 | 09:23 AM
bboyprelude's Avatar
what about in a 92 lude? i pull my 2 ecu fuses. should i pull my clock fuse as well?
tvbrewer80
Apr 1, 2013 01:49 PM
414bb4
Dec 20, 2010 04:43 PM
tbuck23
Apr 1, 2007 05:50 PM
d8168055
Mar 26, 2003 01:54 AM
WheAs MaI MojO
Jan 30, 2003 07:49 PM
