code p0761 after rebuilding transmission
I have a 2003 honda accord ex v6. I have rebuilt the transmission completely including valve bodies. Now after everything is installed I am getting the code P0761. I have tested shift valve C for 12 volts and the correct ohms. Also I cleaned the screen and still get the code and erratic shifting steer coating the codes. If anybody has any advice I would appreciate it. Also transmission fluid is new and topped off. Thank you.
