H22A engine parts/OEM/Skunk2/Accord parts
*Location El Paso TX. PayPal verified.
I am open to offers. However as far as trades right now I am only interested in Hondata S300 V3 (white board), Skunk2 Pro 2 camshafts (H22), or JUN stage 3 camshafts (H22)
If you'd like a quicker response, I check my email daily. [intellectualdope at gmail dot com].
Thanks for viewing.
JDM H22A cylinder head w/ Skunk2 Pro Series springs/retainers - $450
Head has been cleaned. Currently has flat valves installed but will come with an OEM set of valves.
-H22A OEM head bolts and main bolts - $15 each set
-5spd halfshaft - $40
JDM H22A oil pump - $60
5 spd starter - $25
92-96 Prelude manual trans mount - $20
IAB vacuum box (black box) - $20
5SPD VSS - $20
DSM injector pigtails - $?
Prelude power steering pump - $30
___________
Accord specific parts (90-93) CB7 but may fit CD5 too (94-97):
brake master cylinder - $15
brake booster (REBUILT) - $60 (purchased from TASauto only 9-10k placed on it)
NISSIN front calipers w/ good pads &brackets - $30
PT3 ECU - $20
coupe window motor/regulators (both sides) - $20 each
90-91 LX engine harness complete (minus oil pressure sensor) - $40
91 Accord steering wheel (clean) - $20
Alternator, PS, and AC brackets - $10 each
Civic (96-00) H&R Sport springs limited edition. 2inch drop in front, 1.75drop in rear. - $160
Thanks for viewing.
5 spd starter - $25
5SPD VSS - $20
___________
PT3 ECU - $20
Reserved.
Updated with photos. Can send additional photos upon request if you are interested in parts. I'm not much of an active Honda tech member but I'm on cb7tuner. If you like some parts that you see, contact me and lets work something out. Thanks
DC2_ALL MOTA
Sep 24, 2009 07:43 AM
