Car smoking after oil change
Old Nov 3, 2002 | 04:40 PM
95 GaNgStA AcCoRd's Avatar
Default Car smoking after oil change
I just got an oil change last night, and when I got home I noticed a burning smell comming from my car. It was to dark to see what it was and to late go back to the shop, so i didn't worry about it much. Today when I went out, I noticed it again. Smoke was comming from somewhere in the back by the spark plug wires, but I couldn't tell where exactly. Is this normal after an oil change or is something wrong?
Old Nov 3, 2002 | 06:13 PM
Accord94DX's Avatar
Default Re: Car smoking after oil change (95 GaNgStA AcCoRd)
The lube tech that changed your oil was probably so preoccupied by your gangsta status that he forgot to clean the oil off of your exhaust pipe under the oil filter. Itll all burn off.
keep it gansta son
purpl7duece's Avatar
They might have spilt oil onto the header. Check you r oil and se if it is at a good level. Let the car sit for a couple mins then check it. Then check it after you drive it for at least 10 min then let it sit for a few and check it again. if it is lower than before then you might have a leak somewhere.
Old Nov 3, 2002 | 06:52 PM
Default Re: Car smoking after oil change (Accord94DX)
keep it gansta son
All this from a guy with a cash money millionaires avitar. Does anyone else see the irony here? Brian 1st off, I'm not from N.Y. I'm from Pasadena, Ca so the word "Son" doesn't apply to me ok slick? Second what does my "gangsta status" have to do with anything? All you should be concerned about is that I have a 5th gen with a sudden smoking problem. But thanks n e ways for the post you guys, i'll sheck both situations out
Old Nov 3, 2002 | 06:57 PM
MyBigNut's Avatar
maybe you forgot what your username here was?
Anyways.. what he told you was exactly right
Old Nov 3, 2002 | 07:03 PM
Default Re: Car smoking after oil change (MyBigNut1)
My username has nothing to do with my question. Me being a blood or a crip has nothing to do with me being a member, just like ur "big nut" has nutting to do with your post. But once again thanks for the speedy reply to my quesiton fellas
Old Nov 3, 2002 | 07:04 PM
Accord94DX's Avatar
keep it gansta son
boyakasha. rezpeckt. all glocks down for the frontin in mah grill will stop be4 some caps get busted int0 peeps domes yall.
Old Nov 3, 2002 | 07:13 PM
Blood arn't u from Minnesota? I stayed there for a summer a few years back, so I understand your ignorance. You've probally never seen a blood in your life. You watch too much T.V. grow-up K? This is H-T not the icey hot stunnaz message board. When I start making stunnarific post, then flame all you want. I got the answer I was looking for, this is OT someone lock this thread.
P.S.
I would expect more from a Vet like you
Old Nov 3, 2002 | 07:47 PM
Accord94DX's Avatar
P.S.
I gave you your answer splashed with some color. I am not a real person. This is the internet, remember?
stephie1love
Aug 25, 2014 04:01 AM
ThomasP
Sep 9, 2010 01:00 PM
businessmanph
Nov 1, 2006 08:34 PM
Xxcivic99xX
Aug 12, 2004 10:27 PM
Puki
May 19, 2003 11:56 AM
