98-02 accord trans( P2A8 )into 94 prelude question
I was wondering if the P2A8 transmission will bolt into my 94 prelude chassis,mated to my h22a1 without issues ? This is a circle track car. The M2F4 transmission I have is too close ratio for the size tires I need to run. I have searched and my best option other than buying mfacory 5.15 FD to get close to the final ratio I need is 98-02 accord trans. I don't want to spend $750.00 on FD.
In my searches, i have not seen any issues with mating the h22a1 to that transmission. Only problem I have is it wasn't in a 94 prelude chassis they mated them together in. I'm not sure of the differences between mounts on the two transmissions. And I am not sure if my shifter cables and box are compatible with the P2A8 transmission.
If the P2A8 case isn't going to work in this chassis ,I beleive I should be able to use the countershaft, final drive and second gear out of the P2A8 and Install them into the M2F4.
Doing some reverse searching of installing the h22 in to the 98-02 accords I didn't see any thing in those threads about transmission mount woes. I didn't see anything written about having to change shifting cable either. I guess from what I have googled,I won't have a problem with installing that accord transmission into my prelude.
FaulkMall28
Aug 24, 2006 07:46 AM
