fuel pressure
Old Nov 3, 2002 | 04:35 PM
Red Rocket's Avatar
Default fuel pressure
hey guys,
i adjusted my fuel pressure with my fp regulator but now i want to put it back to factory because i just putt a v-afc in and i want to adjust my fuel maps with that.
so if anyone could help me out and knows the factory fuel pressure on a 95 h22a1 it would be greatly apreciated
Old Nov 3, 2002 | 05:55 PM
RAB's Avatar
RAB
Default Re: fuel pressure (Red Rocket)
So you know that the factory pressure regulator adjust itself constantly to maximize efficience of the engine and aftermarket regulators have a constant user defined flow of fuel/gas. I ask that becuase it seems better to have the after market regulator on if you're going to have the VAFC installed.
Old Nov 3, 2002 | 06:01 PM
Firedrake's Avatar
Default Re: fuel pressure (RY8127)
Stock pressure with the vacuum line disconnected should read like 40psi (If I remember correctly)
Brian
Old Nov 3, 2002 | 06:10 PM
RAB's Avatar
RAB
Default Re: fuel pressure (Firedrake)
Brian
Really so with that done a constant supply of gas be injected. Interesting.
Old Nov 3, 2002 | 07:12 PM
LudeyKrus's Avatar
Yep; I believe that was one of Brady's mods on the old hondaprelude.com. Doesn't that give you the max fuel pressure from the stock pump?
Old Nov 3, 2002 | 07:27 PM
Firedrake's Avatar
Default Re: fuel pressure (LudeyKrus)
Right, if you disconnect the vacuum line to the intake manifold, the FPR will run the max pressure it can........which for a stock FPR is like 40 psi......under full vacuum (idle) the stock FPR will usually run like 34-36 psi, and as you get on the throttle it'll start running more pressure (as there is less vacuum) up to full throttle (0 vacuum).......
Both the stock and aftermarket (or modified stock via B&M etc) FPR's behave this way.....on an adjustable FPR the only thing you're changing is the base pressure, it'll still make the same 4-6 psi adjustment based on amount of vacuum if it's hooked to the intake manifold......I haven't ever encountered any FPR's that actually let you adjust the range of psi change based on changes in vacuum, but they may very well exist (it would actually be cool if they did).....
As for Brady's "free mod" of leaving off that vacuum line to run max FPR pressure all the time, I don't think it's a very good idea considering our cars run rich already on the stock fuel maps.....however for dry nitrous setups and ghetto-fuel-management FI setups it might be ok....
Brian
Old Nov 3, 2002 | 08:24 PM
RAB's Avatar
RAB
Firedrake..... good info obviously your knowledgable glad to have you.
Old Nov 4, 2002 | 04:21 AM
DirtyLude's Avatar
Brady's mod is crap. It just mean you run richer at low load. Your fuel will be unchanged at WOT.
The whole point of an FPR is to keep the pressure differential on both side of the injector the same. Injecting into a vacuum is easier than injecting into manifold with atmospheric pressure. So the fpr lowers the fuel pressure while vacuum is present and raises it as load increases. This insures that the same pulse width on the injector at low load will inject the same amount of fuel as at high load, or little to no vacuum.
I'm pretty sure you already know about them, but for some reason it didn't connect. It's called a rising rate fuel pressure regulator. Vortech, Cartech... What's used on ghetto FI setups to push more fuel in the engine based on load by raising fuel pressure at greater than a 1:1 ratio.
Old Nov 4, 2002 | 11:07 AM
Red Rocket's Avatar
Hey
thanks alot guys i really apreciate it. all ur info really helped me out
Old Nov 4, 2002 | 11:19 AM
Firedrake's Avatar
Default Re: fuel pressure (DirtyLude)
Nope, didn't connect Then again, it was early and I hadn't had my coffee yet...... I've actually never used a rising rate regulator on any setup I've ever done......they've all been either VAFC hack/AEM/Hondata with bigger injectors....
Brian
NuclearB18B
Sep 19, 2003 06:20 AM
ProjectCRXtacy
Jul 15, 2003 03:20 PM
iwouldHITit
Mar 8, 2003 09:52 PM
01itr518
Jan 8, 2002 12:17 PM
