Skunk2 mega power, blown out in 6 months?
Old Mar 5, 2015 | 12:26 PM
Jason B.'s Avatar
Default Skunk2 mega power, blown out in 6 months?
A little more than 1 year ago the cat on my 97 civic DX died. I decided to go with ebay piping and later added an 18" vibrant performance resonator and a Skunk2 mega power universal muffler. Mainly, because it was cheaper than getting a new cat.
This car is my DD so it has seen DD every day for the past 6 months. I typically stay within the 2-4k rpm range and will get on it harder when entering the express way but this is not a track car or raced on a regular basis.
I went with the Skunk2 after reading on this form that they produced a good sound, currently it sounds like a busted coffee can.
Anyone else experience this?
Is this normal for them to go bad in such a short time?
Could use a little first hand experience here.
Old Mar 5, 2015 | 03:58 PM
chrysler kid's Avatar
Default Re: Skunk2 mega power, blown out in 6 months?
When my cat went out I purchased another factory unit off of amazon which seems to be higher quality than my oem piece and was only $180 with manifold. When my muffler went out I purchased a walker direct fit replacement which Had great fit and finish and is absolutely silent
I can not comment on skunk2, but My recommendation is to return the car to stock and enjoy the silence and smooth ride that came factory on all Honda civic models
:cheers
Old Mar 6, 2015 | 06:39 AM
24TEN's Avatar
PHANTOM MENACE
You made no mention of replacing the catalytic converter when you put all of that stuff on.
Old Mar 6, 2015 | 10:22 AM
Jason B.'s Avatar
Yep, no cat = clogged muffler from running very rich. Looked down the muffler and found a lot of carbon build-up.
Any way to clean it out? (I know, that's asking a lot)
Old Mar 6, 2015 | 10:40 AM
Nave43's Avatar
Pull off the exhaust and run an acidic cleaner through it? Then soak the muffler overnight in the same solution, come morning rinse and let dry.
Old Mar 6, 2015 | 10:44 AM
Jason B.'s Avatar
Thank you
strigga
Nov 11, 2014 03:31 PM
1quickvr4
May 14, 2005 01:18 PM
GreenBean
May 10, 2003 04:45 PM
