tires size?
Old Nov 3, 2002 | 04:32 PM
-Gambit-'s Avatar
Default tires size?
would a 215/45/16 be to wide for a 98 ek9. I currently have 205/45's and it really dont rub. The car has about a 2.5 inch drop all the way around.
Old Nov 3, 2002 | 05:36 PM
-Gambit-'s Avatar
Default Re: tires size? (gambit33)
little help here
Old Nov 3, 2002 | 07:02 PM
b00stn's Avatar
A 215/45/16 will give you a larger sidewall. If you are looking for for a wider tire contact patch, then go with 215/40/16. You will gain about a half inch in width. You will lose a little overall diameter, but it will only be a few mm. Nothing noticeable expecially when your car is lowered. I just ordered a set of tires in 215/40/16. After I get them mounted, I will have pics and stuff.
BTW, they may rub with how much of a drop you have. I dont think I will be lower than 2 inches at the most. What offset are your wheels?
[Modified by b00stn, 8:03 PM 11/3/2002]
Old Nov 3, 2002 | 07:17 PM
-Gambit-'s Avatar
Default Re: tires size? (b00stn)
i have a +42 offset on my le37's and my tires are 205/45/16. I just wanted a slighty wider contact patch so thats why I am curious about a 215/45/16 tire.
Aaron
Old Nov 3, 2002 | 07:54 PM
94hondaLS's Avatar
go for it!!!!!! they're only 10mm wider think about it a stick of lead from a leadpencil is .5mm
Old Nov 3, 2002 | 08:02 PM
b00stn's Avatar
If you just want a wider contact patch, then go with the 215/40/16. The sidewall height will be nearly identical. If you go with 215/45/16, the sidewall with be larger, thus making a larger diameter. I went with 215/40/16s on the 16s I ordered and they have a 42mm offset as well. But if you are sitting around a 2.5 inch drop, you dont want the extra height from the 215/45/16. 215/40/16 will be perfect.
Look at these spec:
http://www.tirerack.com/tires/Spec.j...CSTA+Supra+712
[Modified by b00stn, 9:08 PM 11/3/2002]
Old Nov 9, 2002 | 03:41 PM
Armaan's Avatar
Here's some factual information for you hyna
Measured with the tire on the wheel:
<U>205/45/16</U>
Section width 8.1"
Actual Tread width 7.2"
Height 23.2"
<U>215/45/16 Tire</U>
Section width: 8.4"
Actual Tread width: 7.4"
Height: 23.7"
<U>215/40/16</U>
Section width: 8.6"
Actual Tread width: 7.8"
Height: 22.7"
Therein lies the answer. If you want a larger contact patch, go with the 215/40/16. The sidwall WILL be "square" because the tire won't be "stretched" as much. They WILL rub, so you'll have to raise your car .5" or roll the fenders out.
Unga.
[Modified by 2.0L Turbo, 4:41 PM 11/9/2002]
zexifiedlude
Jan 26, 2006 03:29 PM
matt2001teg
Oct 27, 2005 02:48 PM
B16Drag
Jan 26, 2004 07:09 PM
itr-j
Jan 4, 2003 11:21 AM
vtecdc2
Sep 22, 2002 08:15 AM
