Audio system issue
I have a 2003 Honda Accord sedan, 137k miles. I changed the battery in December, and since thenI have issues with the audio. After turning on the engine the radio dies for few seconds, then comes back on. Sometimes it happens only once, some other times it happens several times for as long as 10 minutes. The memory is not erased, so it goes back to the same station or the same CD track that was playing. I have never seen this before on any car, did anybody encounter this problem?
Thanks
Levi
Thanks
Levi
Have you tried disconnecting the battery again for a few minutes (make sure you have the code on hand) and reconnecting it? Just disconnecting and reconnecting power to the radio shouldn't cause that issue so it's a little odd. You might have a internal radio problem.
thomis
Sep 19, 2012 03:00 AM
jaed569
May 31, 2009 05:15 PM
