Clutch components
Hey guys,
I'm getting ready to replace my clutch on my '07 Si. Running at around 140K miles right now.
I found a Sachs clutch kit on Rockauto.com for about $230.
Anyone have any experience with Sachs. I used them back in my VW years.
I was thinking of either cutting the existing flywheel or getting a new stock flywheel.
Any recommendations?
Thanks!
Thanks!
Hey guys,
Thanks!
Thanks!
I was thinking of just doing a fine sandpaper run over the flywheel just to get the shine off. Kind of the same as the brake rotors. I got the Sachs plate/disk kit. Only $240 and includes the centering tool, bearing and grease. I have used Sachs before and they do make good parts.
What do you think?
What do you think?
Cool Cool Island Breezes. BOY-EE
I would definitely NOT use the Sachs clutch.
1. Its a ripoff
2. it won't feel as nice as an Exedy.
I would either buy an Exedy OE replacement or Stage 1. Stage 1 has a more robust disk. I would buy the OEM honda throw out bearing and pilot bearings. And Honda ht urea grease.
Or just buy the whole thing from Honda.
1. Its a ripoff
1. Its a ripoff
1. Its a ripoff
I agree on using Exedy. Me and multiple friends have used their clutches without any issues.
What do you think?
What do you think?
Hey B-Serious,
Why do you say Sachs is a ripoff? Just curious. It's part of ZF which is a reputable German company. Just wondering.
If I do go with Exedy Stage 1 do you know if I have to replace the flywheel as well?
Isn't just giving it a fine sanding enough? I spoke to a couple mechanics that have done plenty of clutch replacements and if the flywheel is not scored they just give it a fine sanding if cutting is not possible.
Thanks
Thanks
I priced out the HF02 flywheel and the Stage 1 clutch kit at Amazon. $530 shipped.
Not bad.
You guys are making me nervous.
I want to do the job once and do it right. So, it looks like I'm headed to Exedy parts.
Not bad.
HondaLuv3r4Life
Honda Civic (2006 - 2015)
Mar 2, 2015 05:02 PM
friscorep
Dec 19, 2006 06:56 PM
animated_life
May 5, 2003 02:53 PM
