If you have a squeaky rear suspension - check these!
Old Mar 2, 2015 | 10:14 AM
masospaghetti's Avatar
Default If you have a squeaky rear suspension - check these!
I have a video i'll post later - but - every Honda i've owned has been squeaky in the back, and I bet this is a common issue.
The rear sway bar bushings (not the end links, the bar-to-frame bushings) were producing a horrible squeal when the bar moves. Spraying the bushings with lubricant while installed didn't help. I took them off and added some grease, all is quiet now. It's easy, a single bolt holds each one on.
Item 15 in this image is the culprit (this is for a 93 Accord), list price is $4.83 each.
Old Mar 2, 2015 | 10:33 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: If you have a squeaky rear suspension - check these!
Usually when the stock rubber bushings start getting loud its because they are worn.
Old Mar 2, 2015 | 10:50 AM
Makes sense. It remains to be seen if the grease keeps them quiet for long.
pdiggitydogg
Honda CR-V & Element
Jan 16, 2012 06:19 PM
Flux
Jul 1, 2004 03:59 PM
CYBEREXII
May 27, 2003 10:00 AM
wakaru
Jul 20, 2002 03:39 PM
magic hat #9
Jul 11, 2002 07:38 AM
