Chirping/chattering noise issue
Old Feb 28, 2015 | 06:34 PM
therhett17's Avatar
Default Chirping/chattering noise issue
1997 Honda Accord LX 4 cyl
251k miles
I have a low chirping/chattering noise that comes from around the belts & pulleys area, but ONLY after the engine warms up and is at normal idle. It can also be faintly heard at low acceleration (10-20 mph). It's NOT present, however, when the idle is high, such as when the engine is first warming up or regular driving. Anyone have a problem like this?
Thanks!
Old Feb 28, 2015 | 09:17 PM
holmesnmanny's Avatar
Possibly a loose belt.
Old Mar 2, 2015 | 10:58 AM
masospaghetti's Avatar
Default Re: Chirping/chattering noise issue
^ agree with holmes, try tightening the belt to spec, or replace the belt.
I suppose it could also be a bad bearing in your alternator, power steering pump, or a/c compressor.
Old Mar 2, 2015 | 11:07 AM
therhett17's Avatar
It doesn't really sound like a belt, but I didn't think about the bearings... Thanks guys I'll check it out!
Old Mar 2, 2015 | 11:51 AM
Bearings make more of a roaring/whirling/rough sound.
Old Mar 2, 2015 | 06:22 PM
therhett17's Avatar
Actually "chirping/chattering" really wasn't the best description of it, in fact whirling fits the sound a lot better (sorry, couldn't think of the word earlier). So basically I've got a "whirling" type noise at low idle and low acceleration.
Old Mar 3, 2015 | 04:06 AM
Besy way to test is to remove the belt anyway to rotate each pulley, so you might as well get a new belt. May be the easy fix.
willfly
Apr 1, 2013 08:02 AM
dmanfree
Mar 15, 2013 11:19 AM
JaeEK
15
Apr 21, 2008 06:36 PM
the.hamburglar
Apr 22, 2007 04:52 PM
tsouyporta
Sep 2, 2006 12:40 AM
