2002 ACCORD V6 NEED HELP OR OPINIONS ALTERNATOR ABOUT TO GO? MAYBE?
please if anyone else have had the following problem In a 2002 V6 honda accord let me know what this symptoms are: I have the battery light indicator,the little car indicator with all doors open,trunk,and brake light out, and the emergency brake light, they all light up at the same time and they would'nt come off , those lights come off when I reach about 4000 rpm and then light up again at lower rpms. the car still drives I don't anything wrong with the car but I have the feeling that is trying to tell me (the car)that something is about to go wrong. can anyone help me? does anyone had that kind of problem in a v6 98/02 accord?
I had those symptoms with my 2001 V6 Honda. The belt to my alternator broke, causing my alternator not being able to fully charge. So you may not need an alternator, just the belt, but get it checked asap. It was about two days before it cut off, and wouldn't start.
Thank you so much for your tip my alternator belt looks ok but this was a good advise because I was only going to replace the alternator but thanks to you I'm Going to replace the belt as well my car is a 180,000 miles so is better to replace them both so I won't any future problems related to that. Thank you so much that was a really good tip
aznpridelivin2o3_cg5
Aug 15, 2007 10:14 AM
