Welding fabrication table
Old Feb 24, 2015 | 11:20 AM
Snailor Built's Avatar
Default Welding fabrication table
Trying to get a few ideas for making a table. I see alot of people using metal bracing and such, then the traditional steel top. I want to use wood and then lay a 4x8 sheet of steel on the top. Just wanted to see a few of yall's tables to give me some ideas. Thanks.
Old Feb 24, 2015 | 12:15 PM
Dallasb84's Avatar
Default Re: Welding fabrication table
Go to the scrap yard first and look for medical or restaraunt tables.... Pennies on the dollar. Or.... Buy metal to make one.... Steel will rust and be dirty as ****.
Old Feb 24, 2015 | 02:41 PM
CODE4's Avatar
Not if you take care of it.
Depends what you plan on working with for material, welding process, etc. Just google welding tables look through the images. Plenty of ideas there.
Old Feb 25, 2015 | 06:00 AM
that-guy's Avatar
go to the fabrication section of The Garage Journal. a lot of really awesome table builds in there.
Old Feb 25, 2015 | 06:31 AM
13g-crx's Avatar
This is what I have in my shop at work and I really like it.
https://www.google.com/search?site=&...ml%3B800%3B600
Old Feb 25, 2015 | 07:57 AM
CODE4's Avatar
That is an awesome fab table, but most that fab out of the garage will likely not have the budget for a table like that.
I have one at work and would love to have one at the house too.
Old Feb 25, 2015 | 10:45 AM
essex's Avatar
whatever table you make decide if you want one side open so you can put your legs underneath along with a tig pedal(if you tig),i've seen so many tables with the lower brace going across in the front and they are so uncomfortable,useless to keep your legs under the table, also most people use steel tops and just wipe it down with wd40 now and then.
Old Feb 25, 2015 | 12:43 PM
LKSi's Avatar
I have a 4x8 sheet of 5/8" steel for my table. It works great, just spray it with WD40 every now and again as previously mentioned
Old Mar 12, 2015 | 12:41 PM
I just ended up buying a 8x4 sheet of steel, and am going to weld legs and bracing on with industrial casters.
Hkustoms
Welding / Fabrication
Nov 10, 2012 08:19 PM
V3locity
Oct 1, 2010 09:37 PM
I AM WEASEL
Jun 5, 2009 10:30 AM
TurboEM1
Mar 11, 2006 08:46 PM
Boostless97Lude
Jun 14, 2003 07:12 AM
