1992 honda accord lx
Old Feb 22, 2015 | 04:20 AM
nicus felicien's Avatar
Default 1992 honda accord lx
My Honda accord starts when cold the rpm goes above 1000 and it drops and dies .... When I try to start it again it swings but don't start..... When it starts on cold I try to drive it immediately as I release the clutch it does not take the gas.... I play with it until it revs then I can only drive with speed because when I stop the gas stops again or it just dies
It was a automatic but the person I bought it from changed it to standard
NEED HELP URGENT
Old Feb 22, 2015 | 06:54 AM
94 accord typeR's Avatar
Default Re: 1992 honda accord lx
main relay
Old Feb 22, 2015 | 06:59 AM
Where is it located
Old Feb 22, 2015 | 07:01 AM
Does it need to change??
Old Feb 22, 2015 | 07:23 AM
google or youtube it. every year is different but ALL hondas have them. its a small/large box under the steering column. the solder joints go bad and causes starting/running problems. it is also known as a fuel pump relay etc. etc.(has many functions) auto stores have them locally cheaper online.
Old Feb 22, 2015 | 07:29 AM
Thank you hope it works
Old Feb 22, 2015 | 10:27 AM
jvr's Avatar
jvr
No check engine light?
Old Feb 22, 2015 | 10:32 AM
Are you sure ??
Old Feb 22, 2015 | 02:36 PM
dont take my word for it download a FSM and see for yourself
Old Feb 22, 2015 | 05:31 PM
holmesnmanny's Avatar
NEED HELP URGENT
When was the last time you replaced the spark plugs, distributor cap and rotor, and air filter ?
Old Feb 23, 2015 | 03:54 PM
Lost Again's Avatar
Originally Posted by 94 accord typeR
main relay
Really? READ what the OP posted in their first post...the car will start and run, yes they have to play with the gas to keep it running.....then if they come to a stop the car will die out.
OP- listen and answer the question from "holmes" - the ~$50 you would have wasted on the main relay - tune up items if due will cost less than this.
All I have to add to what holmes posted is that a good cleaning of the TB can't hurt anything. One more thing to think about would be a cleaning/adjustment of the IACV and FITV.
Old Mar 2, 2015 | 05:12 AM
It was the timing belt
It was stretched and it jumped a teeth
StevenC-89Honda
Classic Hondas
Apr 12, 2021 11:16 AM
shoeyb44
Apr 16, 2018 05:43 PM
trwpaper
Mar 20, 2018 08:15 AM
poindex75
Aug 7, 2009 08:19 AM
