1999 Accord F24 Power Steering Tensioner?
Old Feb 20, 2015 | 08:27 PM
oguruma's Avatar
Default 1999 Accord F24 Power Steering Tensioner?
I just put a new Power Steering belt on my 1999 Accord, and it seems to work fine, but there is too much deflection in the belt after driving it around. I don't see any way to adjust the tension on this pump, other than just pulling up on it, which doesn't seem to work. Is there any way to add tension to this mechanically?
Old Feb 20, 2015 | 08:46 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 1999 Accord F24 Power Steering Tensioner?
Looking at the parts diagram it doesn't seem there is a tensioner adjustment like on the 90-97 cars.
Can you place a screwdriver under the pump and gently prise it up and then lock down the lower adjuster?
Old Feb 21, 2015 | 08:55 AM
Lost Again's Avatar
Just as Mike said, you are going to have to use something (big screwdriver, pry bar) to add tension on the pump.
Old Aug 29, 2016 | 06:17 AM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
Sorry for revival kids but I too was confused about this issue. Anyway skimming through the repair manual it turns out there is an insert for a 1/2 inch breaker bar or rachet on the power steering pump to adjust the tension.
AntraxL1
Honda Civic (2001 - 2005)
Aug 24, 2014 10:01 AM
radeonboy
Oct 5, 2007 04:42 PM
woodzy10ec
Dec 2, 2005 11:07 AM
done
May 12, 2002 11:45 AM
