92 Accord High NOx Failed Emissions twice -EGR Ports Blocked
Old Feb 20, 2015 | 06:11 AM
mickfree's Avatar
Default 92 Accord High NOx Failed Emissions twice -EGR Ports Blocked
I had been trying to get my car to pass emissions for several months finally I replaced a cat plugs change the oil make sure radiator was full of water and still failed emissions. finally I had the sense to plug up a timing light and I also drilled out my egr ports are reports after checking the EGR solenoid and the egr valve. After I drilled out the ports I discovered my EGR ports to work completely clogged. After retest my NOx readings:
Before: @ 25 330 @15 1513
After repairs @25 38. @15 48
Timing was way off so I reset to about 17degrees.
nicknack25
Jan 14, 2014 12:08 PM
hatchinprogress
Aug 9, 2013 12:20 AM
the_egg
Apr 2, 2011 08:43 AM
Conan
Apr 4, 2009 07:25 PM
