Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
03 Accord EX Screeching
Old Feb 20, 2015 | 05:41 AM
Liswhitty's Avatar
Default 03 Accord EX Screeching
Newbie here. My '03 Accord has been making a moaning sound recently when started - maybe the past month or so. It moans while it idles and gets louder if I make a turn. Once the engine warms up, the sounds stop completely.
Yesterday, I got the usual sounds, made about 6 right turns to get out of a parking garage (with the usual moaning). When I made a right to turn out onto the street, the steering wheel became very hard to turn. I made another right and then left into a parking lot (very stiff steering wheel, still), thinking I had a flat. No flat, so I sat there and let it warm up for awhile and it was fine all the way home
This morning, when started, it was screeching like a banshee while idling. I let it warm up before leaving and it was fine after that.
I thought timing belt - but I've read mine has a chain (4cyl). Power steering? But it makes noise when idling. Any ideas?
Old Feb 20, 2015 | 08:49 PM
lazlong's Avatar
Default Re: 03 Accord EX Screeching
Sounds like the power steering pump is going bad. Do you have enough fluid? When was the last time you replaced the fluid? It should be replaced every 60K miles or when it goes bad.
Old Feb 22, 2015 | 09:42 PM
VeeSykkz's Avatar
Absolutely power steering. First check belt for proper tension and wear. Next check tensioner. Top off fluid. If all else fails replace the pump.
TrzystaCek
Jun 18, 2018 01:54 PM
relunner4th
Jan 20, 2018 12:28 PM
Mason Edmison
Aug 17, 2017 10:15 AM
Ag3ntSm1th
Dec 31, 2010 12:55 PM
mgsjester
Jan 31, 2009 08:58 AM
