98-01 OEM Accesory INTEGRA Type R Lip Kit (Skirts, Lip, Valences)
I pulled this complete OEM lip kit from a red 2000 Integra. I have all of the OEM mounting hardware.
Front lip: $350 sold for $300 shipped
Side skirts: $400 sold for $315 shipped
Rear valences: $400 sold for $340 shipped
Contact me for shipping, the valences are very cheap and easy to ship, the skirts and lip are going to be tougher due to size.
The front lip: has no major flaws. The only crack is about an inch long and next to the longer passenger side bolt mount, see pic. There is scrapping along the underside which is normal but this can be easily fixed or just left alone since it is not very noticeable once installed. All mounting holes and tabs are fully intact. All screws, bolts and retaining clips are included.
The rear valences: both of them are in great shape with no cracks. The passenger side has a small area where it looks like white scribble lines in the paint. The rear most mounting bolt holder is broken off but I still have them and it just needs to be epoxied back on, I can do this but I wanted you to see the true condition before I complete any fixes. Both valences do include the rubber seals along the top edge.
The side skirts: the driver's side has four cracks. The first is at the very back closest to the rear wheel when installed. It is on the underside and not visible, about 1.25 inches long. The second is about one centimeter long and is tucked in to the area right where the skirt curves up to the rear quarter panel. The third is about an inch long and is near the front most underside mounting tab hole. The fourth is on the front edge section which fits inside of the front wheel well. This is about two inches long and should be fixed most of all.
The passenger side skirt has three cracks. The first is half way upthe riser on the quarter panel section and is about 1.5 inches long. The second is near the front underside edge and is only about half an inch. The third is along the front wheel well section underside rear and is about 3 inches long.
I used to be a detailed so I have the buffer and materials needed to clean these up but if your intention is to paint them then I will not do so. Please let me know what you would like me to do.
Please see my album for many closeup photos: OEM lip kit integra by 02whitemaximase | Honda-Tech.com
