FS: REXMAN'S - RARE Discontinued Parts: JDM, Mugen, CRX and MORE...
Old Feb 18, 2015 | 12:28 PM
rexman's Avatar
Icon3 FS: REXMAN'S - RARE Discontinued Parts: JDM, Mugen, CRX and MORE...
Located in Pittsburgh, PA
Shipping and Paypal fees not included.
Questions? Texting is faster, PM me your # and question(s)
Thanks for looking!
I ♥ my Honda. Sticker AND Window Cling 10. each
Wow
very classic
such bling
do want
much swag
amaze
12"x60" Sun Visor Strip Vinyl (Silver) 10.
Squeegee and instruction included. Needs trimming.
JDM Raybrigs H4H bulbs 90.
JDM PIAA H4H bulbs 90.
SiR Cluster 200.
GReddy 15500351 Remote Switching System 50.
Steering wheel mounted device that allows the user to temporarily increase boost with the touch of a button. This device plugs directly into the back of either Profec so no splicing, cutting, etc., is required! MSRP $132.00
This device works with:
Greddy Profec A
Greddy Profec B (Original)
Greddy Profec B Spec-II
Greddy Type S
Gauges:
AutoMeter Sport Comp Air/Fuel 5.
Autometer Oil PSI 5.
VDO Temperature 10.
Genuine Honda 96-00 Civic Air Bag Tray 100. shipped in the US
Skunk2 5spd. shift k_nob 40.
S2K Start Button 55.
ONE Enkei RPF01 with Yokohama ES 100 100.
15X7 4x100 35mm, 195/50 R15
Brand New, Never Used.
Muteki SR35 Lug Nuts 40.
Progress Coilover Wrench 10.
Mobil 1 M1-104 Extended Performance Oil Filter 6.
Purolator PL14459 PureONE Oil Filter 5.
Genuine Honda Oil Filter, 15400-PLM-A02 6.
OEM Fr. Left Lower Control Arm (EF) 60.
Brand New.
B Series Half shaft 75.
Beck Arnley Fr. Brake Calipers 60. for both
Fits: 90-93 DA Integra, and a bolt-on upgrade for EF's
Semi-loaded w/o pads 077-0535S, 077-0536S
Temperature Sensor Housing 10.
B16 Thermostat Housing 25.
D16A6 Crank Pulley 10.
Adjustable AEM Cam gear 25.
fits: DOHC ZC
OEM Gaskets, etc:
14400-P2T-004 Timing Belt B16A/B16A2 40.
12251-P2J-004 Head Gasket D16Y8/Z6 25.
11251-P2J-000 Oil Pan Gasket Z6/Y8/Y5 15.
12342-PJ7-000 Valve Cover Spark Plug Seal, A6 (x4) 10.
12030-P01-020 Valve Cover Gasket Set 92-95 1.5 non-vtec 20.
12341-PM6-010 Valve Cover Seal A6 (x3) 5. each
91212-P2F-A01 Oil Seal, Crank 5.
(31x46x7) 92-00 1.5/1.6
91213-P2F-A01 Oil Seal, Cam 5.
(29x45x8) 84-05 Accord/Civic
06302-PT2-000 Ign. Module 20.
88-93 Integra
19301-PAA-306 Thermostat 15.
90-99 ACCORD, 91-00 CIVIC, 90-01 INTEGRA
OEM Distributor Cap Assembly 30.
+Rotor and Screw (Z6,Y8)
30102-PT2-026, 30103-P08-003, 30135-PH7-006
NGK (2262) ZFR5F-11 V-Power Spark Plugs 5.
Z6/Y8
Set of (4) Saturated RC SL4-650 Injectors 300.
Brand new, never used!
Saturated Injector SL4-0650
89-91 Civic Interior bits:
OEM Center Console 20.
Door Handles 15.
Window Cranks 15.
OEM Drive Belts
38920-P2A-003 A/C Compressor 16.
31110-P2A-004 Alternator 14.
56992-P2A-003 P/S 12.
D Series Alternator 25.
JRSC belt for D series 10.
OEM Battery Tie Down 10.
EF Civic/CRX ECU kick panel 10.
Civic Owner's Manual 5.
CRX manual SOLD to Hrunner989rex
USDM CRX Hood 40. pick up only
Barbados yellow
EF Tow Hooks 15.
EF Horn 10.
Spare Tire Bucket 25.
83824-SH5-0000
Rear Trim and Emblems:
Type S emblem 10
"Honda" Emblem, Rr. 10.
75712-SH2-00ZJ
SiR emblem 5.
Supercharged emblem 15.
Comptech Supercharger Pulley 30.
PRC 5-7/16" K20Z1 Crank Pulley 50.
1.6 Exh. manifold gasket 10.
18115-P2A-003
Type S Exhaust Manifold 35.
doughnut gasket # 18229-S01-X11 included
Acura 36531-PRB-A01 Wideband Oxygen Sensor 150.
used w/30k, DU2 Denso 192400-1091
Stainless steel Straight pipe 25.
3" diameter
eliminate your cat for maximum performance!
Fuel System:
Used OEM EF Fuel Pump 15.
Aeroquip
(x2) -6 Straight hose fittings 5. each
(x1) -6 90 degree hose fitting 5.
Fuel line used in K20 CRX swap 15.
(from fuel rail to psi reg.)
Walbro 255 LPH HP In-Tank 60.
Brand new, never used. Long considered the best value in aftermarket fuel pumps, the Walbro 255 HP (High Pressure) pump is the most popular for performance applications.
ZC airbox 15.
OBD2B 'small plug' Distributor 50.
99-00 all SOHC civic models only
Single plug / 7 pins total
OBD0 D16 Distributor 50.
TD-02U
Various EF (88-91) Engine harnesses
Need connectors or pins??
2.)Harness 30. and Battery cable 10.
4.)Rough Harness, needs some repair 20.
OBD0 Emissions Controls 10. each
Purge cut-off solenoid valves and dashpot control solenoid valves
Fuse box 20.
Security Control Unit 08E51-S84-1M002 25.
Fits: 00-07 S2000, 98-02 Accord, 03-04 Pilot
SPLASH GUARD, R. FR. 10. each
74115-SH3-010
#7 Shown here: Honda Automotive Parts
RSX K series Intake Air Temperature Sensor 30
Brand new!
2002 RSX Type S Ign. Lock cyl. with key 30.
88-91 Civic Ign. Lock cyl. with key 30.
(EK) Cruise Control Switches 5.each
ARP Head Stud Kit 141-4204 40.
-missing washers
17" 4x100 Wheels 75.
No curbing or rash.
Nitrous bottle keychain 5.
Butterfly knife car key 10.
Redline 75w90 Gear Oil 10. each
Redline MTL 10. each
Redline Heavy Shockproof Gear Oil 10. each
Xbox 360 50.
console only
Mugen Horn Button SOLD to
JDM EK Amber Clock SOLD to jryKC
Rota Circuit 8 15x7 4x100 38mm SOLD to Josh R
CSR Billet Aluminum Filler Neck SOLD to papeluco
Momo 350mm Monte Carlo Steering Wheel & Hub, Booooost! Pro-Comp Gauge, Air/Fuel Ratio Gauge and 5 Point Pyrotect Racing Harness SOLD to shameels178
EF Rubber Seals and EF splashguard SOLD to 90jdmcrxdude
15400-PCX-004 (x4), Moroso filler neck, MFactory drain plug, OEM oil cap and ZIRG fans SOLD to DAslow9
EF K Series Hydro to Cable Transmission mount SOLD to MRDA7
OEM Catalytic Converters and Oil Cooler Adapter SOLD to CW-ITR
1.)Harness SOLD to Sikocivic
(90-91)EX Knuckles SOLD to HATCHingK20
Momo hub SOLD to REX111
Sirius radio and Honda decal SOLD to DieMaster
Rota Center Caps SOLD to danteisme
AP1 S2000 Seats SOLD to Elias J Hiebert
Thule Roof Bike Rack SOLD to Elias J Hiebert
Includes: 400XT Aero Roof Rack System with Standard Bars, 871XT Fairing,
Three bike carriers: (x1) 594 Sidearm, (x2) 517 Peloton, Locks and two keys
Fit Kit 259 (96-00 Civic)
Password:JDM Carbon Fiber Front Lip 96-98 EK Civic SOLD to ^Sammy]!.
3.) Harness with F.I. resistor box SOLD to boostn92vx
CR-X Mugen Pro II kit SOLD to Pandahatch
S2000 Cluster SOLD
Function7 V3 Ultralight Lower Control Arms SOLD to ricoisme26
J's Racing front lip replica SOLD to mrn1120
Neuspeed strut tower bars
Front SOLD to M3THTICAL(EF)
Rear SOLD to todubbled1
Rywire Radiator SOLD
Samco Silicone Hoses SOLD to funkmaster
Circuit Hero shift extender and JDM WRC shift **** SOLD to 94CivicLife
Type R style shift boot SOLD to 94CivicLife
Trim: SOLD to KOOCHYOLOGIST
73541-SH2-003 Trim Quarter Window (X2), 74142-SH3-000 Rub RR. Hood,
74142-SH3-J00 Rub Fr. Hood
Y49 ef7 t-bar SOLD to mrn1120
JDM EF8 Visors (Non-pwr.folding mirrors) SOLD to Cloud Eleven
Discontinued LH&RH Door Moldings BNIB SOLD to chentwoten
Buddy Club P1 Racing Nuts SOLD to matalatto
ARP Extended Wheels Studs SOLD to Hrunner989rex
Moroso Catch Can SOLD to DAslow9
ZC Upper timing belt cover and Modded ZC Upper Timing belt cover SOLD to boostn92vx
LH&RH CRX Fender Liners SOLD to bryancrx
CRX Rear Speaker Grilles SOLD to tommy
EF Complete Steering column cover SOLD to tommy
OEM, never used cig. lighter SOLD to bryancrx
Modified Center Console SOLD to 1320london
CRX Si Cluster SOLD to JK89
Fuel psi gauge SOLD to boostn92vx
A pillar gauge pod and gauges SOLD to 94CivicLife
CRX Garnish Assy., L. Extra Windshield Side SOLD to bryancrx
CRX Center garnish SOLD to JK89
89+
CRX Left tail light SOLD to JK89
89+
Watanabe Center Caps SOLD to oldschool_teg
2 pair of JDM Raybrig Bulbs SOLD to mozzandherb
Fuel Hose #17707-SH3-A30, Valve cover gasket #12341-PM6-010,
Cam seal #91213-P2F-A01, Spark plug gaskets (x4) #12342-PJ7-000 SOLD to AlexCRX
Mugen Oil Filter SOLD to monjarasi
JDM CRX turn signals SOLD to DestODIO
Old Feb 18, 2015 | 01:51 PM
mozzandherb's Avatar
Honda-Tech Titanium Member
Default re: FS: REXMAN'S - RARE Discontinued Parts: JDM, Mugen, CRX and MORE...
Nice parts, bump
Old Feb 19, 2015 | 06:41 AM
rexman's Avatar
Thanks
Old Feb 19, 2015 | 10:06 PM
Certified Honda's Avatar
those F7 LCA
Old Feb 19, 2015 | 11:16 PM
PGR_rexo's Avatar
Pm me on a price for the arp studs
Shipping and paypal.
Old Feb 20, 2015 | 08:03 AM
Jordanbeezy's Avatar
Price of curcuit hero extender shipped to 32757?
Old Feb 21, 2015 | 09:02 AM
13g-crx's Avatar
Pm'd you my number.
Old Feb 21, 2015 | 04:10 PM
rexman's Avatar
All pm's replied
Old Feb 21, 2015 | 07:06 PM
M3THTICAL(EF)'s Avatar
Pm regarding the front strut bar, shipped to 91731
Old Feb 22, 2015 | 05:38 AM
rexman's Avatar
pm sent
Old Feb 22, 2015 | 03:31 PM
rexman's Avatar
bump for brand new parts
Old Feb 22, 2015 | 09:20 PM
JeeK's Avatar
nice kit
could you post pics of the wing brackets? just wanna see how simple they are to reproduce, lost mine when i took the wing off
Old Feb 23, 2015 | 05:16 AM
rexman's Avatar
Hey JeeK, pm sent
Old Feb 24, 2015 | 03:55 AM
rexman's Avatar
bump for new parts
Old Feb 24, 2015 | 06:02 PM
rexman's Avatar
Good stuff up top
Old Feb 25, 2015 | 04:36 PM
rexman's Avatar
Subscribe! New Parts Added Everyday!
Old Feb 26, 2015 | 07:13 AM
rexman's Avatar
Old Feb 26, 2015 | 08:43 AM
b18ctrb's Avatar
Good stuff. Might be interested in the Mugen filter
Old Feb 28, 2015 | 12:30 PM
rexman's Avatar
Thanks
Old Mar 2, 2015 | 07:21 AM
rexman's Avatar
bump, adding new parts today!
Old Mar 2, 2015 | 01:34 PM
SIR Head's Avatar
Bump
Old Mar 2, 2015 | 04:12 PM
lou lewis's Avatar
still have gauges ?
Old Mar 3, 2015 | 05:38 AM
rexman's Avatar
pm sent
Originally Posted by lou lewis
still have gauges ?
Old Mar 3, 2015 | 02:35 PM
rexman's Avatar
Old Mar 4, 2015 | 05:32 AM
funkmaster's Avatar
What engine(s) are the Samco hoses made to fit?
Nevermind, google is my friend and ally.
Interested in the hoses. Please PM me a price shipped to 45238
