High Idle and misfire codes.
I have a civic ex 1999 with about 230k miles in the motor and after a oil change and topping up the coolant the car started to throw the codes P0301,P0302,P0303,p0300 abd p1399 and sometimes the p0505 code with a high idle*about 1.3k*.I changed the IACV, spark plugs and bleed the coolant and its somewhat better but it still throwing the same codes. I suspect it is a vacuum leak but i cant find where exactly. What steps should i take ?
I detected a vacuum leak from the throttle body gasket and my intake manifold gasket by spraying carb spray over these components. You can try and spray certain suspected areas to see if the engine reacts.
washpawryder
Oct 11, 2012 01:24 AM
DOHC Kid
May 2, 2008 11:36 PM
9WON4
Apr 19, 2006 01:34 PM
