Accord 2.3 Not running fine and stalling upto 2500rpm. Check engine light showing
Old Feb 15, 2015 | 03:55 AM
Ankit Poonia's Avatar
Default Accord 2.3 Not running fine and stalling upto 2500rpm. Check engine light showing
Honda Accord 2001 / manual / vtec 2.3 F23A1
Recently had engine head gasket renewed and other seals.
After this work check engine light shows after 1min of starting the car..till then the car runs fine also but then suddenly starts stalling and poor acceleration up2500 rpm..then onwards it runs fine.
Please advise the sensor at fault or maybe lose connection of it..?
Old Feb 15, 2015 | 04:08 AM
Lost Again's Avatar
Default Re: Accord 2.3 Not running fine and stalling upto 2500rpm. Check engine light showing
Without the code it is a guess as to what the issue is/might be.
Not sure where you live but many parts stores will check codes for free. Get the code (not their description of the code) and post it. The code will start with "P" and then four numbers - like "P0304"
Old Feb 15, 2015 | 05:27 AM
Thanks. I guess i will head to a workshop with a scanner facility and find the source for this check engine light.
Old Feb 15, 2015 | 05:30 AM
I'm just wondering how the car run's fine for a the first min when its cold and then the sensors start creating an issue and choking the car till 2500 rpm.
barfo
Feb 21, 2015 06:11 AM
Ankit Poonia
Feb 21, 2015 05:01 AM
jnice
Nov 12, 2006 07:25 PM
halfNhalf-83
Mar 15, 2004 10:00 AM
