car starts few second. shut off instantly.
Old Feb 14, 2015 | 06:16 AM
97civic123's Avatar
Default car starts few second. shut off instantly.
have a ep3.
car runs for about 2-3 second and dies instantly. does not sputter and not gradual.
getting fuel pressure.
checked fuse
checked main relay
immobilizer light not on
Old Feb 14, 2015 | 06:18 AM
Former User's Avatar
Default Re: car starts few second. shut off instantly.
CEL codes?
97civic123's Avatar
Originally Posted by RonJ@HT
CEL codes?
No cel
checked fuel relay.
checked grounding.
checked ignition coil.
Old Feb 14, 2015 | 06:23 AM
Does the CEL work? Did you connect a code reader to the DLC to check for codes?
Old Feb 14, 2015 | 06:28 AM
97civic123's Avatar
Yes. Usually check for cel first.
Old Feb 14, 2015 | 06:37 AM
Will engine keep running with starting fluid?
Old Feb 14, 2015 | 06:38 AM
B20VtecVillain's Avatar
Did you take a look at the harness/ecu? Is this a stock/factory vehicle or modified/swapped?
Old Feb 14, 2015 | 06:41 AM
97civic123's Avatar
have not tried starting fluid, but will think it do the same. seems electrical.
Old Feb 14, 2015 | 06:43 AM
97civic123's Avatar
stock. only cold air intake. even unwrapped the wires and retaped. might be ecu, but no equipment
Old Feb 14, 2015 | 06:45 AM
Give it a try. Could be a fuel injection issue. If not, compression test the cylinders.
By the way, fuel injectors are electrical not just mechanical, though I don't know why you would be entirely focused on electrical at this point.
Old Feb 14, 2015 | 06:49 AM
97civic123's Avatar
will do but checked all the injectors. all spray fine.
Old Feb 14, 2015 | 06:50 AM
How does spark look? Bright white at all 4 plus?
Old Feb 14, 2015 | 06:53 AM
97civic123's Avatar
Yes. btw is a mechanic checking it,not me. he's just been telling me and I'm looking at what he's doing.
Old Feb 14, 2015 | 06:54 AM
Second hand information can be unreliable.
Compression test the cylinders.
Old Feb 14, 2015 | 07:00 AM
97civic123's Avatar
understand, but he looks more capable than I am. will ask him to compression test. anything else.
the symptom though is that it just shut off instantly
Old Feb 14, 2015 | 07:02 AM
It's critical to start with the basics:
CEL codes
Spark
Fuel delivery
Compression
Mechanical timing
Old Feb 14, 2015 | 07:04 AM
If he's competent, he'll figure out a no-start problem lickety-split. If not, get concerned.
Old Feb 14, 2015 | 07:05 AM
97civic123's Avatar
I'll see what he says. will update when I find out.
Old Feb 14, 2015 | 09:21 AM
97civic123's Avatar
this is what he say, I check, compresion,injector, injector signal, coil, coil signal, coil electrical power, fuel pressure , fuel signal, relay signal.
Old Feb 14, 2015 | 06:55 PM
Zedt3's Avatar
It's your timing. pull the timing belt covers and check. More than likely it's off a tooth or two. So check your tensioner while you're at it.
Old Feb 14, 2015 | 06:57 PM
97civic123's Avatar
How sure are you? btw it uses a timing chain Iif that matters.
Old Feb 14, 2015 | 07:26 PM
Is he stumped?
Old Feb 14, 2015 | 07:29 PM
97civic123's Avatar
Is he stumped?
Yes. he trying to rule out immobilizer or ecu. he said it requires the more expensive diagnosis machine to test the ecu which he doesn't have.
Old Feb 14, 2015 | 07:35 PM
I'd be suspicious about this mechanic. What he's charging you for this diagnosis?
Based on the list of things that check out fine, I don't see how the ECU could be the problem. Did he check the mechanical timing?
Old Feb 14, 2015 | 07:40 PM
97civic123's Avatar
I'd be suspect about this mechanic. What he's charging you for this diagnosis?
No he's not. He's just trying to rule it out. He said then he can check the wiring. I'll bring it up with him. btw problem started with the crankshaft seal. I was getting it replaced due to oil leak. I was watching what he was doing and all he did was remove the Serpentine belt and crankshaft bolt. I did replace the crankshaft sensor thinking it was that.
