99 civic IACV
Old Feb 13, 2015 | 03:52 PM
jdmoscar703's Avatar
Icon6 99 civic IACV
I have a 99 civic for some reason there is an annoying noise coming from the IACV Sounds even louder when I put on the air intake. Sometimes when I open the throttle and let go of it sounds like the engines wants to turn off idle drops for a sec and goes back to normal it's turned off on me sometimes when I play with the throttle. What could it be?
Old Feb 13, 2015 | 04:12 PM
Former User's Avatar
Default Re: 99 civic IACV
Clean the IACV and make sure there's some slack in the throttle cable.
CEL codes?
Old Feb 13, 2015 | 04:29 PM
I cleaned the IACV. Still having the same problem
Originally Posted by RonJ@HT
...make sure there's some slack in the throttle cable.
CEL codes?
Old Feb 13, 2015 | 04:43 PM
Still need to get the scanner. Other problem I put coolant in my radiator let the car warm up atleast 15-20m turn off car. All my coolant drains but it dosent come out. What could that be that is causing that?
Old Feb 13, 2015 | 04:55 PM
Pressure test the cooling system and also rent the AutoZone block tester kit.
Old Feb 13, 2015 | 04:59 PM
Alright, will do that thanks
Old Feb 13, 2015 | 05:09 PM
NotARaCist's Avatar
I never narc'd on nobody!
All of your coolant drains but doesn't come out? What do you mean by that? It also sounds like you aren't bleeding the system properly.
Put the front end of the car on jack stands (or park up a hill). Remove your radiator cap. Top the radiator up, and start the car. Let it run until the radiator fan has cycled three times, constantly making sure the radiator stays full. Once you've finished that, replace the radiator cap, fill/empty the radiator overflow tank until it is between the low and high lines.
Old Feb 13, 2015 | 05:50 PM
Just did what you told me to do and fixed it. Thanks, but I'm still having problems with my IACV
Last edited by Former User; Feb 13, 2015 at 05:51 PM. Reason: Don't make that mistake twice.
jdmoscar703
Feb 11, 2015 05:56 PM
Hmotoredcoupe
Apr 14, 2013 07:41 PM
thead
19
Aug 9, 2012 07:06 PM
bradabu
Mar 14, 2011 01:30 PM
ezeedude
16
Feb 26, 2008 12:06 PM
