temperature sensor broke off in block
Old Feb 13, 2015 | 11:48 AM
jeinboden's Avatar
Default temperature sensor broke off in block
so the temp gauge on the cluster is indicating that the car is over heating when its not so i picked up a new temperature sensor.*when i went to take it off the threads i guess were stuck and it broke off flush with the block. i picked up a set of tap and die but there is just no room for leverage to get in there. anyone have any ideas on how i could get it out with ought taking the radiator hoses and air filter off?
Old Feb 13, 2015 | 02:20 PM
tim73's Avatar
Default Re: temperature sensor broke off in block
Ive learned...its best to just bite the bullet and move the interference, which gives you room to work, than trying to work around the stuff. Not a big deal to unhook that stuff...and put it back. Get a set of ezouts. Soak in penetrant oil, and give it a while to work. Drill a nice straight hole, its really soft metal. Then use the ezout...to work the broken sensor out.
dls_tech
Dec 11, 2010 07:36 AM
GSRex22
Jul 6, 2010 03:12 PM
krysted9354
Dec 28, 2008 12:43 PM
R6Boy69
Jul 5, 2003 02:51 PM
Brian_92GSR
Mar 27, 2002 09:17 PM
