rod torque for f23 rods
Old Feb 11, 2015 | 01:27 PM
Kris's turbo's Avatar
Default rod torque for f23 rods
Can some give tell me if this is right because I have never heard of torquing honda rod bolts this way. I was told torque them to 14lbs and then turn the bolt a 1/4 turn, is this correct?? If not what torque do you use?
Thank you
Kris
Old Feb 11, 2015 | 01:52 PM
Charlie Moua's Avatar
Default Re: rod torque for f23 rods
i doubt that's right...14lbs only?
Old Feb 11, 2015 | 02:12 PM
MAD_MIKE's Avatar
MM Gruppe B
Per 98-02 FSM page 7-32
"Apply engine oil to threads, tighten to 20N-m(14lb ft)..."
"mark connecting rod and bolt as shown(shows marks 90° apart)"
"Tighten nut 90° to mark"
"Check bearing clearance"
Old Feb 12, 2015 | 04:00 AM
Fitz Williams's Avatar
10 Year Member
I assume that this applies to factory rods and not aftermarket rods?
Old Feb 12, 2015 | 11:56 AM
Yes factory bolts thank you for your help
andyrew500
Mar 4, 2006 02:53 AM
N20civicB18
Mar 8, 2005 04:40 PM
Nextelbuddy
Feb 12, 2004 12:39 PM
ladysman
Mar 21, 2003 12:08 PM
BlwnBlue
Jan 22, 2002 04:31 PM
