Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2014 civic lx brake problems and rev issue.
Old Feb 10, 2015 | 12:05 PM
jeffparjout1's Avatar
Default 2014 civic lx brake problems and rev issue.
Hi I am having issues my 2014 Honda civic lx cvt. One is that the front brakes seem to be wearing away. The plastic wheel cover is very dark and brake pad dust is all over my car. I only drive from school to home and occasionally other places. I don't brake hard. Is there a problem or just supposed to do that? Other problem is when I start the car, the car revs to 2,000 rpm while pressing the brakes at start-up. I am not new to Honda vehicles. Thank you
Old Feb 10, 2015 | 12:43 PM
DaveSi677's Avatar
Default Re: 2014 civic lx brake problems and rev issue.
Why are you pressing the brakes when you start the car for? If it's in Park you should be moving. Try starting the car without touching the brakes and see what happens. Also where are you located? If the car is revving @ 2000 rpm what is the temperature outside?
As for the brakes well brake dust is normal and if you have a lot of brake dust it could be because you are braking a lot harder then usual. Have you done a brake job lately? What pads are you using?
Old Feb 11, 2015 | 02:57 PM
97emsedan's Avatar
Brake dust is inevitable. We all get this on our rims. The 2k rpm issue is curious. Do not step on the brakes when you start the car. The CVT is an automatic transmission and won't require any pedal depression to start the car.
Try this and let us know what you find.
Old Feb 11, 2015 | 05:51 PM
I live in Raleigh, North Carolina. The weather here isn't too cold. I tried without pressing the brakes and 95% of the time, the rev limit goes to 2k rpm. I am parking on a hill but I don't know if that effects it. About my brakes, I brake veryyyyyyyy softly. I don't slam on my brakes.
Old Feb 12, 2015 | 08:23 AM
DaveSi677's Avatar
Brake dust is something you won't be able to control really... it's normal unfortunately.
How long does it stay at 2k rpms before dropping?
Old Feb 12, 2015 | 05:45 PM
After I start the car up it revs to 2k rpm then about 2-3 seconds later it drops but stays at 1,500 rpm for quiet a while. I will try to post a video if possible.
Old Feb 13, 2015 | 01:23 AM
av911's Avatar
Sounds normal to me. If the engine is cold, it's just warming up.
Old Feb 13, 2015 | 03:02 AM
ricb20vtec22's Avatar
From the way you are describing the start-up issue, that is normal. As for the brakes, in 2013 - 2014 Honda started to use Carbon-based brake pads which is why you are seeing more dust then you normally would on previous models. Nothing to be concerned about.
Old Feb 13, 2015 | 08:30 AM
Thanks for the replies.
Felix Chan
Suspension & Brakes
Oct 16, 2018 12:49 PM
JDMhonda90
Jun 16, 2010 11:11 PM
Brando316
Apr 16, 2010 07:39 AM
TechBill
May 17, 2008 09:22 PM
