Honda Accord 2001 2.3 Vtec Sensor Issue.
Hi, I recently got engine head gasket renewed and the valve / timing seals renewed. In this process all sensors were disconnected / removed. Throttle body removed and reconnected.
On completing the task the car is not accelerating properly up to 3000rpm..it picks up very slowly/ less power..after that things become normal. The sensor light is showing.
My mechanic does not have a scanner and we are trying to identify the cause.
We doubt the o2 sensor or the Vtec solenoid. Can this be it ? or anything to do with ideal air valve ?
Hondas up til the mid 2000's still have the two wire blue connector.
It will only give you the OBDI code, but that should get you pretty close.
lrcoope4
Jul 22, 2011 11:11 PM
rushabh21
Dec 21, 2010 08:44 AM
